89 Evinrude 110 hp prop size
flaxterra
I have a 17.5 aquasport with a 89 110hp evinrude on it. i bought the boat as a fixer upper. the motor came with no prop. Can anyone tell me around what size i may need. i am lost when it comes to prop size. i know people change prop size depending on what they want out of there boat but i dont have a starting off prop to go by. any info would be great! thanks.
itsaboattime
Re: 89 Evinrude 110 hp prop size
My '87 E-rude 110 has a 13 3/8 X 17 on it. I have the motor hanging off the back of my 1983 Four Winns Marquis 160. She's 16ft. and right about 1300 lbs loaded. I get a hell of a hole shot she tops out at about 42 mph.
I think I could go a lil bigger on my prop because if I let her, she'll rev out to over 6300 rpm.
I would start with this size if I were you and go from there.
flaxterra
thanks for the info. Is that the prop that came on your motor when you got it or did you upgrade to it?
itsaboattime
I just got this motor (used) less than a month ago. This prop was on it.
