89-90;50 hp Force Oil Seal replacement
Byteme 2
Help! I'm replacing the seals in the lower unit and don't know how to remove & replace the oil seal between the gear case and water pump. I also need this for the seal on top of the water pump housing. The sealoc book doesn't explain it at all and I'm ready to put a little flame to the seals to hopefully remove them. Any advice will be appreciated.
