Re: 89 70Hp Johnson Shift Linkage
Thanks for the headstart, I have removed everything in the way of the shift rod. I can see where a connecting block it attached to the shifting lever which is connected to the shift cable. The connecting block has a pin or someting through the shift rod. I need to get this pin out.
However, I have limited vision to see any screw head. I have felt around and it's a clean application. Could this be a drift pin ? Or did the previous owner break it off and not fix.
I have done several water pumps on smaller motors but this is a terrible set up.
