GreenSkeeterMissouri
Thread starter- Joined
- Aug 12, 2009
- 11
Just bought a 1989 quantum bass boat with 50hp force. I was told the boat needed impeller pump. Hooked up muffs and no water pissed. Removed lower unit and I don't see why its not pumping. Sure the rubber paddles are a little bent but looks alright. Also I notoced there is no gasket or silicone between lower inut and motor. Is this right? Also does this motor have a thermostat? Is the impeller bad or the tube plugged or what? Its a 89 50hp force thanks for replys
