Re: '89 19' Fishmaster restoration
Make sure to get 100% & even coverage of the PL on the plywood. A notched trowel works well. You might make a few 1/2" holes thru 1 of the ply pieces. PL can trap air between the sheets, preventing good adhesion. The 1/2" hole gives it some place to vent out. Also makes another mechanical connection between the 2 pieces of ply.
You can use either epoxy or polyester resin, BUT if you use poly you need to also use fiberglass mat or cloth of some type. Poly resin alone is brittle, and can crack over time. Epoxy, you can use solo.
If poly, use 2 or more coats w/ 1.5oz CSM or 1 CSM layer & a layer of heavier fabric over that, all in 1 layup. Coat both sides & the edges really well. If you do the 2 layers in 1 layup, just wait 15min +/- for the 1st to get tacky & then apply the 2nd. Done like this you won't have to sand between the 2 'coats'.
For epoxy I'd use 2-3 coats per side & coat the edges every time you do a side (they'll get 4-6 coats) scuff the epoxy between coats.
For tin boat builds, most prefer epoxy over poly.
Coat the inside of the bolt holes w/ epoxy resin. Won't take much, even if you decide to use polyester.
Some also use spar varnish, but 4-8 coats, sanding lightly between. I'd still use epoxy for the bolt holes.
