Re: 88 Sea Nymph Fish N Ski rebuild
Nice job on the power wash. I'll be thrilled if i can get mine that clean. Yes, all the corrsion is under where the foam was. Sides and transom look good.
I'll probably go with a gallon of gluvit, only a few bucks more than 2 qts. and I and slather it about with reckless abandon
Any thoughts on using the bedliner in leiyu of carpet? I'm hearing good things about it and really dont know of an alternatve to carpet.
Nice project. Very similar to an SC SS. Is most of your corrosion in areas where the foam was? We have a theory that the foam traps water (possibly salt water) against the hull and causes corrosion. That one of the reasons why many of us have gone with sheet foam or noodles in our rebuilds. I powerwashed my hull inside before Gluvit-ing it and it came out really nice and got all the limber holes pretty well blown out.
I really don't think your going to find a better sealant than Gluvit. I did all my rivets and seams in my 18' with 1 quart. If you went with two quarts you should really be able to seal it up well. I would not mess with the bedliner.
