Hello,
I have an 88 OMC Seadrive v4 1.6 I have no rpm and is not charging. Does this issue point to a bad rectifier?
Also I have tried hooking the tach to the yellow wire from the stator and still no rpm. I also have a test rpm gauge that will not register any rpms aswell.
If I have to replace the rectifier looks like I have to pull the flywheel. Am I able to use a harmonic balancer puller to do this?
Thank You
Thank You
