88 omc 5.7 motor swap
jeicher
Hey guys,
I’ve built a 350 gm motor to swap out m omc 5.7.
I’m at the stage of completing and ready to stab a distributor. I’d like to just go the HEI route as I have new ones on the shelf. I’ve read of people having different issues time after time. What I want to know is if I go HEI what else needs changed?
Boat is an 88’ four winns
Okc 5.7l
Cobra stern drive live
matt167
You will want good life vests and burn cream for later. If you survive the gasoline explosion…. NO bs either. An HEI is not ignition protected. Hopefully your built 350 is built to marine specs as well or you could pull water in with the wrong camshaft
Hey guys,
Okc 5.7l
Ayuh,..... Welcome Aboard,...... As noted, the automotive Hei is a no-go, as it's not ignition protected,......
Dui makes a Hei that is,.....
The go-to boat replacement ignition is the Delco Voyager system, which is reasonably inexpensive,......
agree, no automotive ignition stuff...
full
matt167
I had no clue Davis built marine HEI. I can only imagine what they cost. I know what his stuff cost 10 years ago when I was looking into one for a 200 straight 6 Ford
jeicher
Bondo do you have a link or more info I’m on that voyager? Thanks
jeicher
Ok delco est ignition system ordered. Now to exhaust. Should I replace all the manifolds and risers or just inspect, replace gaskets, and reuse?
jimmbo
Just curious, what are you using for the Fuel System, the Alternator and Starter, the Water Pump, even the Core Plugs?
Lou C
Are you in a freshwater region? If so your manifolds & elbows may be re-usable.
I still have my original Prestolite points distributor. If you go with Delco EST, or other electronic distributor, you're going have to change the original ESA module, if you still have it. CDI Electronics makes ESA modules that will work with electronic distributors.
