88 Johnson Lower Unit Re-install
hstroller
Hi<br /><br />I'm having problems re-installing the lower unit on an 88 Johnson 50 horse. I didn't look at the shifting rod location when I took it apart. What direction should the hole in the shifting rod shaft be facing? I'm having trouble getting the pin back into the rod when I reassemble it.<br /><br />Thanks much
