subfixer
Thread starter- Joined
- Apr 30, 2011
- 21
I'm attempting timing checks via the SELOC manual. Their procedure measures the piston location with the timing pointer at the 12 TDC position and then again when the piston returns to that position after rotating the flywheel CCW. Splitting the distance between those marks is supposed to identify the TDC location. It then tells me to move the timing pointer to that position. Problem is the new TDC mark is far more than the pointer adjustment will allow. What am I doing wrong? Also when I do a timing light check at idle speed, it shows that I am timed at about TDC -3, rotating the throttle rod doesn't seem to change the timing position. Appreciate any insights.......
