1. You fully raised, then disconnected and plugged/capped the tilt cylinder raise hyd line (one that goes to the bottom of the tilt cylinder)1. You fully raised, then disconnected and plugged/capped the tilt cylinder raise hyd line (one that goes to the bottom of the tilt cylinder)..... Green line YES!!
2. Lowered?????? the motor to place load on the tilt cylinder and NO LEAK DOWN AND STAYED UP........I could not lower the motor. Did you mean remove the wooden block? Yes we did and the motor stayed up.
3. Lowered the outboard motor to full trimmed down position. .... Yes, after reconnecting the Tilt cylinder lines.
not the bottom.
4. Removed the lower trim cylinder line from the valve body. This line is the one located on the upper portion of the trim cylinder. Plug and cap both the line and the valve body port..... ????? Confused by this question Upper ?? Lower?? Are you talking about the red line or the yellow line? I did this to the yellow line. Is that correct?
5.- 8. below I understand. Above #4. If the yellow line was the correct line , I'll wait for your answer,( LEAK DOWN DOES NOT OCCUR), I will rebuild or should I say ,I will attempt to rebuild the trim cylinder.
5. Raised the motor to fully up position (Full tilt). Note this action puts no load on the trim cylinder, instead its hyd circuit which is in parallel with the trim circuit is being put to test. By disconnecting the LOWER trim cylinder line and plugging/capping it, prevents the fluid from returning to the VB, since the tilt cylinder is not leaking as proven in the previous steps.
6. Mark across the swivel and stern bracket with a marker to note movement.
7. If leak down occurs, troubleshoot the valve body. The logic behind this, since the tilt cylinder is PROVEN NOT TO BE LEAKING, and the "return line" (line on top of the trim cyl) from the Trim cylinder is capped/plugged, then the only way fluid can leak is in the Valve body.
8. If leak down DOES NOT OCCUR, REBUILD OR REPLACE TRIM CYLINDER. NOTE THIS IS WITH THE CONCLUSION THAT THE TILT CYLINDER PASSED THE LEAK DOWN TEST IN THE PREVIOUS STEPS, which you did correctly. The logic behind this is that since the "return line" of the Trim cylinder is plugged/capped and fluid has no where to go, except with the return line of the Tilt cylinder (which was proven not to be leaking down), then it proves the Valve body is not leaking and working properly. So the problem lies only with the trim cylinder.
