88 force 125 prop help!
Asnyder19
I need some help! I can not figure out why the props im buying won't fit. 88 force 125 single exhaust 13 1/4" x 17. 15 spline. I just recieved my second prop in the mail from Amazon and it still doesn't fit. Getting really fed up
Jiggz
In what sense does it not fit? Is it because the anode being there? Some newer props 15 splines for Force require that you remove the anode to make it fit. Some provide something like gear case ring, which you should not install also for Force motors.
Yegboats
I come up with the same number as Redfury fp685-3 I don't see any cross references.
