renegade15
- Mar 29, 2009
- 99
Cleaned carbs...several times. Repaired fuel line leak, but top carb on my 1988 evinrude 60 is still running lean...what next? It was sneezing a little on the flush muffs but stopped in the water. After a little run at high speed I checked the temp and all heads and the thermostat housing were 139-141, fine. Pulled the plugs and the top plug is definitely running lean. Not scorch the plug lean, but definitely not running right. What next? Open to any and all suggestions!
