bostonmike
Thread starter- Joined
- Apr 9, 2007
- 8
I have an 88 Johnson V4 90hp. It has run fine all season, had the carbs rebuilt, spark and compression test done at the beginning of the year. This past weekend after being out for about 7 hours, I was running WOT when suddenly it cut back to about half speed and then died. It started up again without a problem but when I pushed it to full throttle it ran about half power at best. I was able to get back into harbor without a problem, it was just very slow going.
When it died I didn't hear anything pop or crack and there was no smoke coming from it. After I got home I hooked it up to the earmuffs and it started with no problem again, went into gear fine. I pulled the four plugs and the two in the top cylinders were fine, but the two bottom seemed like the oil on them was a bit watered down.
Does anyone have an idea on what my problem may be? I'm hoping it may just have gotten water in the intake or gas? Hoping it does not require a rebuild or anything too expensive.
Thanks for any insight!
