88 50HP Force Steering Pivot Shaft
sunchasers
I have the above mentioned engine. I am trying to replace the steering pivot/knuckle. I have the nut removed from the shaft that runs thru the pivot but cannot get the shaft to let loose. Is the shaft press fitted or threaded thru the engine cover? Any advice or tricks to free this shaft up will be greatly appreciated. Thank you.
