88 150 XR4 Warning Horn Overheat?
Nachman
Went out today and before the first crank the warning horn sounded (long tone) and after a couple of off-then-on, off then on the horn went to test tones and she cranked up.
Is this an indication of a thermostat sticking open or maybe a faulty horn? It did take about 30 seconds for the p-stream to show....
I'm still having a rough idle and hard start.....(88 Merc XR4 150 Troubles thread)
Thanks,
Dave
rodbolt
Re: 88 150 XR4 Warning Horn Overheat?
sounds like the normal test, beep beep beep is oil and the long tone is overheat.
the alarm control module at key on tests both. long beep followed by about 3 beeps.
j_martin
You might get a continuous tone from the oil alert module. It is not normal. It can be caused by battery low voltage.
Any short to ground, either through the oil alert, the Ot sensor, or a mouse bite will sound the horn.
hope it helps
john
Nachman
Thanks John, I appreciate your experience as I have noticed your responses to other threads. Sure wish you lived next door....If you're ever in Texas stop in for some BBQ!!!
Thanks again
Dave
Nachman
Also thanks to you rodbolt...BBQ for you as well!
Dave
