87 Starcraft CSS 180 Transom Help
kterry111
hey everyone its nice to be among friends. its a mad world out there..lol i need to replace this transom but these corner wells extend out on the corners. anyone know where i need to cut to replace transom? not much room on the inside at all. any help would be appreciated...
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Looks like a glasser, unfortunately most everyone works on aluminum hulls on here. Might want to try one of the Fiberglass hull sections.
SHSU
Watermann
What little I know about glass boats I can tell you have 2 options, cut and repair after the transom replacement or pull the cap off. Most likely the stringers are rotten too, lots of work ahead I'm afraid.
ezmobee
With the windshield off already you're already looking pretty close to "popping the cap". Then you'll have easy access to the whole transom. Make sure the boat it well supported because you don't want it to splay out and then you'll have trouble getting the cap back on.
kterry111
Hey thanks for responding is there another way other than popping the top to fix transom?
