87 omc Cobra with Ford engine presenting odd overheat situation
ZeeCee
Hey all, let me thank all of you guys for your help last season, i bought a beater project boat for my first boat and it has really been an adventure. i replaced my ESA, replaced the bearings in my upper unit, and many other things without so much as a post!!
So here is the situation: i have an 87 Bayliner Capri with an OMC Cobra sterndrive and a Ford 2.3L engine ... On the water for the first time this season i idled for around 20 minutes sitting still will no problems. After gaining some confidence i decided to run down the river and after about a mile or so i noticed my temperature gauge was maxed so i quickly shut down the engine. I felt the water intake/exchanger and it was cool to the touch, but the red hose was hot and the black hose was cool. I squeezed all the hoses to make sure they had water in them and they did. When i turned the key back on the temp gauge was back to the normal position (around 160-170 F)... it went from maxed to normal in about 7 minutes without turning the engine or pumps at all .... confused, i decided to run back to the ramp but on the way gauge was back to maxed so i shut her down again. This time the intake/exchanger has very hot as were all the hoses.
Got back to the ramp with the trolling motor and everything back on the trailer and home carefully. At first i was thinking it was the gauge malfunctioning, but then it seemed to actually be over-heating. I was then thinking it was the thermostat, so i disconnected the water inlet into the front of the engine (above the main pulley and slightly to the right) but there was no thermostat inside, not even a bevel or recession to fit one, just an open hole into the block. Does this system use a thermostat? or did a previous owner simply take it out? or is it part of the OMC and not the engine? (note: uncovered a lot of abysmal "fixes" by previous owners over this poor boats 24 year life and have done my best to correct them)
I checked the impeller before i left to to river and everything was sound and clean.
does anyone have any thoughts or advice on things to check? i can submit pictures, go check something, just let me know.
thanks for reading!
Joshua Nichols
Re: 87 omc Cobra with Ford engine presenting odd overheat situation
Yeppers 0982554
THERMOSTAT
I don't think you looked in the right place.. Pull that housing off the exhaust manifold.. The one with all the hoses going to it...
ZeeCee
Alright, i will check on that today and let you know how it goes.
ZeeCee
very nice. got the front of the manifold off easily and found the little thermostat. it was not exactly seized or stuck, but rusty and looked like it could use replacing.
Looks like the weather is going to be against me here in Tennessee for the weekend, but i should get a replacement in around the middle of next week. Will post the results.
Robbabob
Okay, you spilled it... where in TN? t-storm just moved through and not going to be boating weather all weekend! :-(( so very sad!
Welcome to iBoats!
ZeeCee
thanks for the welcome and for giving me an excuse to update my profile information. =) Sparta TN, its just about an hour north of chattanooga up hwy 111.
