87 mercruiser 470 alpha one trim not working
SHANEWHITLEDGE
Boat sat for a couple years and i know trim worked before it sat any suggestions. Anyone have an exploded view of trim components, wiring diagram, etc...
starwriter
Banned
Re: 87 mercruiser 470 alpha one trim not working
I had the same problem with my 1990 4.3 Liter Mercruiser alpha 1.Trim didn't work after seating for a yr or more.
First thing I did was check the trim pump motor make sure it runs.I ran a 12 volt hot wire to the motor to verify it works.Once I verified that the motor wasn't locked up.I found corrosion on the terminals & silnodes to the pump motor.I unhooked each wire connection one by one & cleaned each connection.After that.I took apart the throutle handle trim switch & trailor switch & cleaned them as well.After that everything worked.I beleive your problem is either motor locked up or bad connection from corrosion on the terminals & silnodes.A test light will help you check things as well.First thing to do is to check to make sure the motor isn't locked up from seating.Is the silnodes clicking?From corrosion to a little mouse chewing on wires can cause many things.No reason for a wiring diagram or to mess with the wires if the trim worked last time you used it.Clean is the answer."Clean".Just,like carl on the movie Sling Blade,"Got any Gas?",Is the battery charged?
starwriter
Banned
In addiction,I removed my trim pump motor from the boat completely.Two wire motor sytem.One wire is for reverse,The other wire is for forward.Housing is ground.Basically simple system.I tested the motor using a 12 volt battery charger.You must test the motor first thing.Bearings on the motor could be rusted up or inside brushes went bad.If the motor works/runs?That's a good sign.If not?That's your problem.Next step is silnodes at the pump motor mount area.Either a bad/cut wire somewhere.Or corrosion on the terminals & silnodes or bad silnode.
Bt Doctur
Can you describe the trim pump? square alumunum res,m round metal res, plastic res, number of solenoids?
SHANEWHITLEDGE
Trim pump is square top with round metal resevoir. I took off and polished all wires and terminal filled reservoir, tapped the pump repeatedly and while using a jumper wire from battery to signal wires on solenoids pump works both ways. But at the switch on the throttle lever it will only go down not back up. Bad switch? Bad wire from switch to solenoid???????????
SHANEWHITLEDGE
