87 Merc 70 Hp No Spark On Top Cyl???
sbb1933
I'M NOT GETTING ANY SPARK ON TOP CYL . HOW DO I TEST FOR COIL OR BOX? iT WAS RUNNING BUT IDLE WAS ROUGH AND TOOK ALONG TIME TO GET UP ON PLANE I THOUGHT IT WAS CARBS BECAUSE I COULD TURN THE SREW ON THE MIDDLE CARB ALL THE WAY IN AND IT MADE NO DIFFERENCE ON THE IDLE OF MOTOR.
Laddies
Banned
Re: 87 Merc 70 Hp No Spark On Top Cyl???
You can switch the wire to the coils at the box to check but if it's not a coil and it's probably not you will have to test the system with a DVA of OHM meter.
sbb1933
What is a DVA and are you talking about the whole ignition system? I have read that a bad stator could make the switch box go bad. Thanks
Laddies
Banned
A DVA is for testing voltage or the Ohm meter test resistance, I did not say anything about replacing the whole system that would be stupid anyway heres the test, do what you want.
sbb1933
Sorry I meant testing the whole system not replacing it Thanks for info I ordered a manual today
