I've got a 1987 Johnson 110 VRO that already had the VRO disabled when I bought it. There's no beep when you turn the key to accessory position, and I'm pretty sure there should be. I've taken apart the remote controls and I can see the alarm speaker inside, and everything seems to be hooked up. I'm not sure if the disconnection of the VRO was done improperly and disabled the alarm system.
Photo of the place by the starter where the VRO used to be
Not a great photo, but you can barely see down there past the fuel pump where the oil line is plugged
Disconnected plug, probably related to the VRO.
Is it okay for that plug to be disconnected? I can't find anything it would plug into. Is it likely that my expensive piece of plastic alarm speaker is just dead? Is there a way to test them with a battery or something?
