87 Johnny 50 Compresion spec?
thehermit
I Have 90 (cold) on both cyl and am still trying to get to start. What is this engine comp supposed to be?
Pony
Re: 87 Johnny 50 Compresion spec?
Thats ideally a little low, would be better if it was somewhere in the 100's 120 to 140 would be perfect............BUT...........its even. It could simply be some carbon build-up and sticky rings. (could even be the gauge) When you get it going you could do a decarb and see if that brings it back up.
I don't think it is the reason you can't start it though, as it should run fine on the compression.
JB
There is no spec except that the cylinders compress within 15% of each other, Hermit. 90psi cold is fine.
Go to the Engine FAQs to solve your starting problem..
Good luck. :)
thehermit
Thanks JB-Pony. I have help on another thread on the ignition system troubleshoot.
TH
