87' evinrude 30hp hard to start
N1NE1
My 87' evinrude 30hp outboard is hard to start,it will fire right up if i pump the choke/primer knob then stall when that fuel is out.if i do this for about 5 minutes it will eventually start and run just fine with no problems. Once its starts and warms it will fire right up again and again without any issues. Took off carb and cleaned but that didnt help. Motor says mixture 100/1 but i run it at 50/1 anyways. Any idea what could be wrong. Its definetly a fuel issue but which one
bktheking
Re: 87' evinrude 30hp hard to start
Have you checked compression readings?
N1NE1
Yes compression is over 100 on each
bktheking
This is how the system works:
Manual Primer
The manual primer operates as both a fuel injector and an enriching device. The fuel injector operates w/o air being drawn through the motor. The enriching device is an alternate path from the carburetor to draw fuel through the primer and add more fuel during cold-start.
Put motor in neutral
Place the throttle in the start position.
Cycle through one or two full pull-push operations on the primer knob. This will squirts fuel into the intake manifold.
Pull out primer knob one half-to full out. This will engage the cold-start enricher circuit.
Pull the starter rope, or press start button until the engine starts.
As the engine begins to run, slowly slide the primer knob in. The rate of choke disengagement will vary greatly with each individual outboard. Some require immediate disengagement, others require slow disengagement. Know your outboard.
Visually inspect tell-tale for solid stream indicating proper cooling.
As the choke is disengaged and the motor warms up, slowly back the throttle off from start to the shift position.
Are you starting it this way?
N1NE1
I havent tried doing this, just thought i was supposed to pull it out a few times to get it started at first... I will try this way tomorrow and get back to you.just bought this nmotor, it was in someones basement for close to 15yrs without use. Very very clean motor, looks new.thankyou
bktheking
Sounds like your procedure is factoring out the "cold start part" , I wouldn't have known either unless i found it in another thread. Good luck!
