day skipper
- Jun 13, 2007
- 9
Greetings, Everyone! The problem I'm having started sometime last year. Motor starts good after priming, it will idle fine for about 5 minutes or so, then will cough and die, even at low forward speed. If I keep priming, it keeps running. I took the carbs off for a cleaning, and there was what appeared to be oil in the bottom of the carb cover, or burnt fuel since I plugged the VRO last year and started mixing fuel/oil. Anyway, cleaning the carbs did not help. It also seems that as I start increasing the throttle, speed increases slowly, much hesitation. Runs fine at WOT, so I'm assuming that it's not the fuel pump. I did replace the thermostats beginning of last year, don't know if this would have anything to do with it. Changed the plugs recently to Champion QL78YC, gapped at .040, which I saw was recommended on this forum. Going to 1000 Islands in a month, and I gotta get this thing runnin right. Any and all help is GREATLY appreciated! Thanks!
