87 Bayliner capri cuddy restore(Actually Citation Caprice)
Woodonglass
Honorary Supreme Mariner
Re: 87 Bayliner capri cuddy restore(Actually Citation Caprice)
I too, just found your thread. NOTE**** ROT does NOT stop!!!! Black mushy wood at the bottom will soon, and I mean SOON be at the top. If you like this boat, and want to keep it for more than 5 years then REPLACE YOUR TRANSOM!!!! If you READ the threads on Transom Replacements here on the Forum you will see that Many others in your same situation thought the same thing only to find that their transoms needed to be replaced. Listen to their experience and do what needs to be done while you are already there.
produceguy
Replaceing the transom is not that hard. You can do it.
I'm still learning myself but don't feel like your alone on it, lots of good help out their and if you don't get to many replys it could mean your on the right track.
I'll be watchin my freind.
snobdr
Seems like alot of work for a transom that is 90% good. There was no moisture in it. and it wasnt soft. What came out was only dark in color.IM going to shoot CEPS into the bottom 3" in holds drilled on 1" centers. and that should sure up the problem.
foobash
I am having trouble replying with my android (anyone know a good forum app?), so had to wait until I had time to get to a computer.
It looks like you have a decision to make. I will be testing my transom this weekend. I have to pick up some 3M 5200 before I do this. Have you been using this stuff to seal your test holes? From my research on here, it is supposed to be the best stuff to seal any holes that are created. You should also download the epoxy/fiberglass book from west systems, they show some nice techniques, especially to reinforce and partially replace bad wood. Either way, I am not even thinking about replacing the transom until next fall. This is because I have a good outboard already mounted on there that hasn't given the previous owner any problems in the past three years, and I just don't have the time to do it. It has soft spots in the floor, but I ripped out the carpets and I want to do the whole thing (even though the bow is almost perfect).
Did you put the CEPS in yet? I would (from my researching) dry it out as much as possible before using it. Seems like the best way to do this is with an IR light. I have one left over from an old reptile cage. I am planning to re-fiberglass the transom. I will sand it down; dry it all out with IR light. Then I will do some soaking with Propylene glycol. This is the old school anti-freeze, not Ethylene glycol (that you find at Pep-Boys). It is way more expensive, but way more toxic. The more toxic the better for rot, as you have to literally kill it to end it. Seems like the CEPS attempt to make a barrier to seal it from spreading. So I figure why no try to kill it too. I will do several soak intervals while I am prepping my deck. I will also do some small cross-drilling on the transom and stringers and reinforce with epoxy. This will act somewhat like rebar that is used in concrete slabs. From what I read on here, over doing things will probably do no harm. However my opinion is that transom replacing is over-rated. If it is holding the motor (doing its job), then don't worry much about it. You will see warning signs, it won't just fall off. I am sure others on here will totally disagree with perfectly good reasoning. It is your call.
I am curious, how many gallons of epoxy did you use? I think I am going to order 10 gallons to be on the safe side. I have not decided if my wood used for the vinyl seating should be epoxy/fiberglass completely. The original wood was not fiberglass but definitely was treated with some cheap looking water-proofing sealant which still looks/feels really good for an 87. It's all the vinyl that is cracked, so I am redoing the all of the seating.
I learned a lot about boating on here. I started on here just to get tips on outboard engines, then came across the restoring forum and decided to buy a project boat. The best thing is to use the search tool on here to save time. About 99% of the time I only search in the titles. I used broad terms like deck, floor, transom, etc. They will mostly come up with something related to repairing/replacing. You should also try search strings of just your make and/or model. This gave me a lot of ideas on the final look of the boat that I want. For example, this one guy (forget his name) on here used this paint called Durabek and snap on carpets. It is the most impressive looking floor restoration I see on here. He also has some nice pictures. You might get lucky like me and find someone else on here who is restoring the same exact boat (his boat condition was totaled). Also, when I get a lot of hits from searching, I just click on the threads that have pictures (paperclip icon).
I have to get a few pics together and post my own thread (will try to do by next week).
Keep posting, it is very interesting.
Rich
proshadetree
As you can tell in this photo the lower section of mine was gone. It past the drill test with good white wood. I hate to see a person fix everything but and then go back to fix the but.
foobash
Agree. At some point in time every transom will probably have to replaced. My idea is to buy myself time until I repower. Of course my plans could change.
Did you have any symptoms when running with that transom?
Rich
proshadetree
First time out leaked like a siv. The people who say jump on it and what ever are nuts. Mine was solid as a brick. the lower bolts were tight it just let a load of water in.
foobash
Did you try any Epoxy or some type of sealing? I guess it would be harder with an I/O since you literally have a hole in the boat that has to stay sealed.
What are your thoughts on outboard transom repair? This is what I have, Mercury 135HP where the mounting is bolted flat on the transom (not the "hanger" type mounting). What would be the symptoms of a bad transom of this type?
Rich
proshadetree
cracks along the corners drawn in spots near the engine mounts, black wood shavings form test holes.
