87 40 hp vro where is the fuel pump?
marinemike43
I cant seem to locate the fuel pump on this motor...Is it in the vro pump?
When its running and I squeeze the bulb,its not getting hard,can squeeze it all the way in while running.
Thanks Mike
tashasdaddy
Re: 87 40 hp vro where is the fuel pump?
fuel pump is part of the vro pump. the bulb is not going to be hard when the motor is running, because, once the motor starts the fuel (VRO) pump, is pulling fuel thru the bulb.
marinemike43
Is there a way to test this ?
I would suspect a pressure and vacuum test.
Didnt know if there is a easier way
countvlad
is the motor running good? whats the problem? if bad fuel pump you couldnt run WOTor run poorly... do you have an alarm on the boat? low oil flow is a constant beep every 1/2 second
is there a way to test it.. sure there is... http://forums.iboats.com/showthread.php?t=283363
If it Aint Broke Dont fix it
tashasdaddy
that test is for 4 stroke motors, not 2 stroke. inboard outboards etc.
tashasdaddy
exactly what problem are you having???
marinemike43
When I get it up to high RPMs in the water it dont run good,then if I choke it it will run better.
