87 15hp (J15ECUD) No power under load.
siberspace2004
It revs Fine in Neutral, but bogs down under load. I've cleaned carb, changed plugs, yet still no difference.
They all rev up in neutral.-----They will do that with one cylinder not working.-----Test compression.----Test spark.
oldboat1
Additionally, if it struggles or quits when shifting into gear, the throttle idle speed might be set too low, or the air/fuel mix is a little too lean.
