86 mercruiser 170 ignition problem
Cynicaltrip
Hi guys I have a 86 mercruiser 170..put electronic ignition in it..rebuilt motor completely set timing to 6 btdc...have 3 ohm coil new...replaced purple resistor wire from choke to coil with a non resisted wire...have power to choke..coil..and everything else that needs 12v when key is on....motor will crank and crank nothing...checked for spark when cranking and it doesn't have any spark until you let go of key then it will throw 1 spark at end of cranking....about to commit a violent act I'm so fed up lol....figured id toss this problem out there and let the minds better then mine have a go at it!...the only thing I could possibly think of at this point is shift interrupter switch bad maybe? Thx again for any help....
Don S
Re: 86 mercruiser 170 ignition problem
Do you have the purple yellow wire that goes from the starter slave solenoids I terminal to the coils + terminal hooked up?
stonyloam
You may have a bad contact in the slave solenoid. In your 470 the coil gets its voltage from the small terminal on the slave (purple/yellow wire) while the starter is cranking. You do have the purple/yellow wire attached right?. Try this: run a wire directly to the coil plus from the battery + and give it a try. Also if you have a voltmeter, see if there is any voltage on the coil + while cranking. Let us know how you make out.
Don was a little quicker but at least I feel a little more confident about my answer now LOL.
Cynicaltrip
Yes I have the purple/yellow hooked up from slave..its also new...I will have to check voltage while cranking tomorrow and get back to you guys thanks for the responses so far...
Cynicaltrip
ok update....with key on i have 11.2v at coil + side....... 9.8v coil+ while cranking....after i got those readings i ran a wire from battery + side to coil+ side had 12.8v at coil+......cranked it and cranked it still nothing....shifter is in nuetral...i tried all sorts of different positions same result...can a bad shift interupter switch cause my issue and how can i test to see if that is the problem....or will that not cause wwhat im dealing with?...thanks again for the info guys much appreciated...:confused:
Don S
It shouldn't have anything to do with it. But disconnect it and see if you get spark.
Don S
Has it ever had spark since it was installed? Is all of it there. Had one guy here found his kit didn't have all the parts. Check your kit to the instructions and packing list.
Cynicaltrip
yea i bought a pertronix kit but the magnet wouldnt fit called them they said they didnt make a kit for my prestolite dizzy..so then i ordered HOT SPARK kit came with everything module, magnets the works...when i purchased the boat the motor was seized...so i took it and had a machine shop work the block and then i put all new into it from there...so i personally havent ever seen it fire up lol..so thats why im questioning parts that are not new on this motor...i reused the dizzy for the electronic ignition along with the cap and other then shift interupter everything else is new....how should i go about disconnecting the shift interupter?....do i need to join the white/green stripe wires together? and the black to black?...and just remove the unit itself..? sorry if im asking rookie ?'s lol thx again for any info!!
Not a good sign there. There are guys on here with pertronix on their 470 but not sure what dizzy they are runnin.
Don S
Just disconnect one of the white green wires, and don't let it touch anything. See if you have spark.
if no spark, you have distributor problems. Do you still have the old points setup that was in the distributor?
Cynicaltrip
ya the pertronix rep said they didnt make a kit for my prestolite dizzy...screwdown cap with a 23.75mm dizzy cam lobe....so i switched to HOT SPARK kit and it fit nicely....maybe pertronix does and rep was eh but anyhow i switched and would love to get spark now lol....any ideas fellas?....
Cynicaltrip
k don ill try that tomorrow...thanks again i appreciate it...i'll post update then...and no i dont have the points setup .....or that would of been done awhile back lol switch back to a points system and try it..
dingdongs
did you put the rotor back in???????
the spark has to get from the coil to each lead via this.
Cynicaltrip
Yes rotor is back in.....I'm stumped gonna try disconnecting white/green wire from shift interrupter tomorrow...see if that works I guess...
dingdongs
remove cap and then remove centre wire from dizzy and hold it a 1/4" off block and crank.
should be sparking 6 times per revolution of the distributer.
Don S
Uhhhhh, it's a 4 cylinder, better make that 4 times per revoluton of the rotor. Hopefully the distributor isn't turning. :p
Cynicaltrip
Ill try that tomorrow also good advice....I will update...
Cynicaltrip
K update time.....Pulled the cap off and disconnected coil wire off cap....held it to engine block and cranked motor...it had plenty of nice looking spark...so if i have spark firing from the coil like that does that mean my cap and rotor is bad and thats why no spark at plugs im assuming?....and i tried looking into the replacement cap for the prestolite 4cyl marine dizzy and its an elusive creature....any links to a cap and rotor would be appreciated also thanks guys!!
Cynicaltrip
ya dave thats the only place i found that has screw down cap like mine. also...was wondering if anyone sold rotor by itself or good idea to get points just to have since im running electronic ignition.....also from my above post would a bad cap and rotor cause my situation ?...
