86 Johnson tilt and trim
89 redfin
I have tried to get my tilt to trim up but it will not.
I hooked a positive to the green wire on the trim motor and it goes down, but when I hook it to the blue wire it does not go up, click, it only gets very hot.
It was working fine.
any help is appreciated
Thanks!
RRitt
Re: 86 Johnson tilt and trim
you probably have a short in the field frame. the green wire is not connected, but the blue wire gets hot? then you're going to need a new trim motor.
