86' Doral Citation Fuse Panel/Diagram
Mitchmedic
Hey everyone,
Im new to the site so your forgivness is needed. Ive been searchiung thru the threads and I hadnt found anything like the question I have. Im a new boat owner but have been boating for years.
I have an 86' Doral Citation 350 V8 Chev engine I/O, having some technical diff-a-ma-culties. I cant find any info on what amp/volt fuses go in my fuse panel, a lot of my fuses are broken or missing so I cant obtain the proper fuses until I know....you know....as a confirmation that most of the stuff on the boat is ACTUALLY cooked rather than just missing a fuse hehe.
If anyone has a wiring diagram or any info they would like to share I would be greatfull, thanks in advance.
Silvertip
Honorary Supreme Mariner
Re: 86' Doral Citation Fuse Panel/Diagram
A wiring diagram is likely not published and if it was, it would not likely contain fuse sizes. But there is a simple solution. Step 1) Determine what device(s) is/are connected to each circuit. 2) Add the current consumption of each of those devices. 3) The correct fuse is one that is 10 - 20% higher. Or, look at the wire gauge connected to each circuit. 16 gauge = 10A max. 14 guage = 15A max, 12 gauge = 20 A max. Devices that have their own internal fuse normally have a label that states current requirements. If you don't know what that is, google the device name, make & model and look at the specs.
Mitchmedic
Silvertip....Thanks man, thats a wicked reply, sounds simple enough, Ill look at all my wiring and see what I cant come up with, but I am by no means electrically inclined hehe!
Silvertip
Most wiring from the fuse panel to the devices is 16 gauge which can be fused to 10 amps. If you went higher than that the wire would burn before the fuse blew hence the fuse limit depends on wire size. However, you can fuse less than that to protect the device that circuit feeds. A radio for example may draw only a couple of amps so you wouldn't fuse it for 10 amps. More like 5 in that example.
JBF 1962
That is darn good info to know! Thanks for posting the question Mitchmedic n thanks for the answer Silvertip! ^^
