dkonrai
Thread starter- Joined
- May 9, 2009
- 719
i have a 50 hp force, 1986. its got coils and points. i finally got the flywheel off, i had to buy a hydrylic puller, and modify it. at first attempt, i pulled the gear teeth from the flywheel. i then had a buddy modify the jaws (welded some tabs on the jaws) and finally got the darn thing off. it took alot of beating and pb buster.
i lost spark in number one, and it turned out to be a broken lead wire to the points.
the manual i bought was for the 87 up motors. so i dont have the point setting. what is the the point setting?? i set them at .20
i have a parts motor, 79 45 hp. i pulled the stator and flywheel off that motor and installed it on the 86 50. will this work ok? the motor starts ok, but i still have a coil issue.
has anyone tried using a coil from a dci/ 1987 or later on this points/coil motor? i guess im asking if i can safetly use the later year coils instead of the older styler coil. i dont care if it looks odd, i can fabricate a bracket if need be.
on a good note, i changed the rectifier and installed a cheapie ebay regulator. i will post pictures and results as soon as i get this baby in the water.
thanks
dino
thanks
dino
