86 131a engine and dist. Rotation
cannonford57
Starter was replaced by someone else and I believe that is where my running and cooling probs began.can anyone enlighten me on the rotations.thanks
Nickypoo
Re: 86 131a engine and dist. Rotation
If you are looking at the front, the engine spins clockwise.
The distributor spins clockwise looking from the top.
You should verify this. The alternator may have some arrows on the fan in front indicating the rotation. Also, your timing marks should go from higher numbers down to zero from left to right if it spins clockwise.
Don S
The engine is standard LH rotation viewed looking at the flywheel, distributor rotor turns CW
cannonford57
The trusty clymer #770 shows the dist turning ccw on page xii
Don S
Not a surprise. I think if you check, they also have the wrong firing order ............... is it that Seloc :facepalm:
cannonford57
Yeay probably not a suprise 1342 is that right? It is a clymer
cannonford57
So which one is more reliable for information?
