aladin_sane
Thread starter- Joined
- Jul 3, 2011
- 45
OK, the stats first. I have 120 psi compression in all three cylinders. I have synced and set all three carbs. Now the problem. When I start the boat, it starts and idles OK. I can hit the throttle and the boat takes off and runs fine for about twenty seconds. The boat then stalls and sputters to a stop. If my copilot sits in the stern and squeezes the bulb every 15 seconds everything runs fine, so I assume the problem is the fuel pump. I rebuilt the fuel pump, new gaskets and diaphragm. I didn't replace the check valves, but I did inspect them, and the open and seal as they should. After the rebuild, the results were exactly the same. I checked the fuel pick up and replaced the fuel line from the tank all the way to the fuel pump including the bulb. I checked the vent line and it is clear. So, what's next? I am thinking I have a problem with the impulse line. I have not checked it, but that is the next place I am looking. It appeared fine when I had the fuel pump off.
Anyone have the solution for this one?
