FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a 85hp force tilt and trim. I took most of the pieces off a 125hp force outboard. When I hit the switch in either the up or down direction, the relay just clicks. Where do I go next with figuring out how to make this work?
Two wire t & t motor? Disconnect the blue and green wires that go to the motor from the wiring harness. Connect them directly to 12 volts. The motor should spin and the outboard should tilt. Reversing the blue and green should cause the outboard to move in the other direction. Report back.
CAUTION: The trim motor draws a fair amount of current and will create sparks when you touch the leads directly to the battery terminals. You don't want to have the battery anywhere the fuel tank vent or other sources of gas vapors. The leads from the trim motor should be long enough for you to put the battery on the ground on the starboard side of the transom.
Pull the wires from the relays. Spray WD-40 in the relays and on the contacts.
Plug em back in and see if that helps.
NO help: Then the next thing is like NYBo suggests.
I got this same issue. A new male relay end is not expensive but the female harness end is. your trim tilt motor is prolly good but its the trim relays. I still have not figure mine out either but after replacing the male relay i ordered the female harness. I also cleaned all my grounds with sandpaper too so try that. I took a dremel with a special head to my relay and i cleaned the inside of female ends manually with a cut up fingernail file. none of this did anything for me so thats why I ordered the female harness
