Jmcjunkin3
Thread starter- Joined
- Jul 15, 2017
- 49
Hey guys, so I had a topic previously open about my 1977 85 Johnson. I got everything tweaked out, and took it out on the water. The butterflies in the carb open fully, and the engine sounds like it's running very smoothly, but it's not hitting full rpm. Won't even get up on plane. Here is what I had on my other thread, figured opening a new thread on this new issue would be for the best...
Alright guys, better day today than my last run, but also not good. I started the boat up, let it fast idle for a bit, then took it off the trailer. Tied it up, parked the truck, and got back in....it took off, but only if I kind of hit it suddenly. I thought maybe It'd clear. Well...I got out of the no wake zone and went WOT. It sounds super smooth, no missfires whatsoever, but it just wont go upstairs AT ALL. It wouldn't even get up on plane. This boat used to top 45 easily....made sure the throttle plates were opening fully, check. Made sure the timing advance was all the way up, all good there. Decided to beach the boat and investigate further. Well....the battery was deader than hell. Fully charged and cranking well when I left the dock, suddenly dead...jumped it off and it ran perfectly fine, just wouldn't go upstairs again. Got it back to the dock, hooked my mulimeter to it, and got a lame 12.21 volts...mind you, this motor was putting out decent voltage just the other day...over the course of a minute or so, it rose just a tad to 12.24 or so, but never the 14+ I should be seeing...could a charging issue be causing a lack of RPM? It seems reasonable to think that if the coils/powerpack arent getting enough power, they won't perform as they should...any suggestions would be great! Here is a video I took of the situation.
https://drive.google.com/open?id=0B6...klfc3dOUWZ3bTg
