85 Johnson 50 horse lower unit??
JKK8633
Hi im fairly new to this forum but just had a question on how to remove the lower unit from my motor. Ive got it dropped about an inch but it wont go any further anything would help thanks.
tashasdaddy
Re: 85 Johnson 50 horse lower unit??
did you disconnect the shift linkage under the carb?
JKK8633
No but im assuming that would probably be a good idea now that you say that. Do you think thats all that is holding it up or is there more you have to remove on the top end.
tashasdaddy
it dropped, that is all that is holding it, start some of the bolts back in to hold the lower while you disconnect shift linkage. easier to remove starter, and bottom carb. disconnect battery cable first.
JKK8633
Thanks for the help i got it out now to figure out whats wrong then get it back in. Thanks again!
