captain413
Thread starter- Joined
- Mar 27, 2008
- 10
I have a 1973 85 H.P. Johnson and it is not getting enough fuel. I took it out to test it yesterday and it was only getting fuel to two cylinders. It has a carburator on top and on the bottom. When I throttled up the two high speed ports on the left side were spraying feul but the ones on the right were not so the engine would not reach high rpm. While we were going I sprayed some starter fluid in it and the engine reved so it doesn't seem to be the leaf plates on the right side so I believe that the high speed orifice is clogged on the right side of both carburators but I wanted to see if anyone else has run into this or see if anyone has any advice. Thanks in advance for all your help.
