85 force question
saulgonzalez
okay i got two question's my first one is can someone tell me if i need a new shifter. the motor is on a 85 capri bayliner and i used to be able to pull neutral and give full throttle and it would idiel hard and fine. now i pull the shifter to engage neutral my lower unit engages forward.second question were the l-drive and lower unit meet there are tiny holes near the bolt's what are this and should one be leaking small amout's of oil when run.
12Footer
Re: 85 force question
Answer-one; Not likely, but you may need to dismantle it to repair,re-adjust, or lube it. These binacles are a pain in the ice to werk on, so do not attempt this without the manual handy, and you are somewhat mecahnically inclined. They're a good design, but it's like werkin on a large watch.<br /><br />Answer-two;Those holes are there to allow the lower leg (not watertight) to drain. Some oil is normal, but large amounts of oil, or grey water/oil mix may indicate a bad seal in the lower unit or gimbal. To check, drain/inspect lower unit lube. If contaminated, you'll know where to procede.
saulgonzalez
thank's 12' were can i send the controll to get it rebuilt or do you know were i can get another.i usually work on my own truck and boat but the manual i have has a very limited controll section.i've checked the oil, thru drain plug and is black with no sign's of water contamination.
timfromfc
I have an 86 Bayliner Capri and had to replace the control box. The original was a Morse MNS that you pulled out to get into neutral. I replaced it with a used Morse SL-3 that I bought for $100 from Great Lakes Skipper. I didn't have to do any adjustments either. I also called Morse and the faxed me the installation manual which helped a lot.
