I'm assuming when you did the switch back, you also did the same with the trigger wires, orange and green trigger to Or and Grn on CDI wires. Double check the wiring again against the diagram. And if everything is OK, it could mean the CDI is bad and needs replacement.Switched it back so cdi2 connector 1 is powering coil 3 and still no go.. (same connector that gave no spark to coil 1 originally.. I'm thinking maybe the CDI is bad.. I don't have a way to test it unfortunately.. anyone have any thoughts I can try before I order a replacement?
I wonder if the CDI was always bad and they had it wired for 2 and 3 for some reason...
Note the schematic drawing, the power wires going to both the CDI's, Yel and Blu. going to the terminal board. Note two blue wires being terminal'ed together feeding the #1/#2 CDI and none on the #3 CDI (which only has the yellow wire). Could it be that the Yellow wire powers up only the #3 (orange ckt) and if you decide to use only the Red ckt you should connect the blue wire instead.
