85 evinrude
smith88
Is it ok to put the primer bulb next to the engine for easy access?
oldcatamount
Re: 85 evinrude
Sure is. Easy access should always be a priority on a boat.
Solittle
Re: 85 evinrude
Yep - - the engine has no idea where you put the primer -
emdsapmgr
Re: 85 evinrude
When priming the primer bulb, it works best when the arrow on the bulb is pointing up. (the internal ball valves work best that way.)
