Sorry if this is a little long I just want to explain everything well. I bought a 19ft sea nymph on monday with a 1985 90 horse johnson VRO with the oil pump disconnected. Yesterday I went to go on my first fishing trip with the new boat. It took a bit to start up at the dock but once warmed up it seemed to run good and idle good. Left the dock and putted out all running smoothly. Idled up to get on plane and just before it planes out the motor bogs down and only sounds like its running on 2 or 3 cylinders. I can idle it up not on gear but it has a slight miss. So I limp it back to the dock and go home. Pull the plugs and all are dirty but the two passenger side ones are wet. Ok new plugs. Today I go for a test run with the new plugs. Same thing. Idled good at the dock and JUST before the boat planes out it bogs down and seems to only be running on 2-3 cylinders. Plugs are all dirty again. Im guessing it needs a carb cleaning. I pulled some gas out and it looks good and smells like gas. Any ideas?
