84 Stringer exhaust housing removal.
doral1985
Any good tricks to removing the ex housing from the lower gearcase, 7 botls removed but seemst to be stuck around swivil housing bearing. Used lots of WD40 and heat. any suggestions?
Frank
doral1985
Re: 84 Stringer exhaust housing removal.
Finally got it separated, pullers, wd40 and heat, tightened puller up a bit over a couple days, more heat and more wd40, this am it let go and its off, now to clean up top of lower unit and remove old seals in swivil bearing housing.
