84 johnson tilt/trim
hardluck
Looking for tilt/trim unit for 1984 johnson 60h.p motor.Looking for used or rebuildable unit.thanks for the help.
ddaigle
Re: 84 johnson tilt/trim
Get yourself a CMC tilt and trim from I boats. I have one on my 70 hp and I love it. You can mount your motor higher due to the setback and gain more speed and efficency and they are very reliable.
Reggie08
I have a CMC as well (currently holding my 55hp Yamaha while I rebuild my 90hp Rude) and it works great.
johnjsa
For those who have a CMC especially the 70 HP. How high do you have your motor setting on the CMC unit & do you trim it all the way in coming out of the hole. I have a CMC on my boat which has a Johnson 70 on it & had some trouble getting on plane. But it could be another problem with my carbs causing the problem. thanks.
papasage
i have a CMC and i git it set and leave it . it is on a 15 ft. bumblebee bass boat with a 55 hp . don`t worry how fast it gits on plain . when i have a heavy load i might tilt it a little to git it up on plane .
i also have a 1974 on a 15 ft cimmmaron bass boat . it gits on planne quicker never raises the frunt
