'84 Johnson 70 Damaged Piston (Pics)
Socak
I have a 1984 Johnson 70 that was reading a bit low (125, 120, 95) in the lower cylinder so I pulled the cylinder head cover to figure out what might be the problem. The 3rd piston, which had low compression, is slightly damaged, and all the pistons were fairly dirty. The cylinders themselves appear to be in fairly good shape, no scuffs or abrasions. What is the best mode of attack to fix this, just take the piston out and replace it and how should the pistons be cleaned? The carbs appeared to be in good shape, but they are being taken off and cleaned. Also I have ordered a omc manual to help
Cylinder 2.jpgCylinder 3.jpgCylinder1.jpgPiston 2.jpgPiston 3.jpg.
Capt Ken
Re: '84 Johnson 70 Damaged Piston (Pics)
You are going to have to replace the piston. The indentions in the top is from pieces of its rings that have broken.
dodgeboy1979
Replace all three at the same time, a machine shop can hone the cylinder walls for ya before you put the new ones in.
Socak
Ok thats what I figured. The hole in the center of the pistons is normal correct? Do the other two pistons look salvageable after a major cleaning?
boobie
I would pull the mtr apart and check the other pistons for any scuffing. If they are okay just put new rings on them. You may have to have the one cyl with the broken ring bored out to oversize if there are gruves in it. You may not need all new pistons. Good job on getting the OMC manual. Lots of good info in it as far as rebuilds.
w.ross
Are these holes towards the center normal?
Pulled my plugs out today to fog the motor for the winter and noticed the same thing...
Curious.
Thanks guys,
durban
Master Chief Petty Officer
i have striped 3 70hp with worse pitting on top of the piston & in the top of the cylinder head too , this is not caused buy broken pieces of rings as they where all still intack & in good shape after striping , this is caused buy water getting into the port or through cylinder head & spark & water is a conductor of electric . :)
Socak
Mine was cause by a blown skirt on the bottom piston.
Chinewalker
Yes, the hole is normal. It's a center point for machining the pistons...
Curious.
Thanks guys,
Chinewalker
The sort of damage in the photos is mechanically done by someTHING bouncing around inside the combustion chamber, in this case a piece of the piston skirt. Water doesn't bang into a piston and leave a mark...
durban
show me the scars in the sleeve then i will be-leave you .
Faztbullet
If water was entering cylinder the piston tops would be steamed cleaned and display no carbon, the electrodes would have a slight rust film on them when removed and set to dry and excessive water would hydro-lock the engine as water will not compress. It will also wash the cylinders of lube and scuff the sides.... and a spark plug will not fire in water or steam.
Faztbullet
If water was entering cylinder the piston tops would be steamed cleaned and display no carbon, the electrodes would have a slight rust film on them when removed and set to dry and excessive water would hydro-lock the engine as water will not compress. It will also wash the cylinders of lube and scuff the sides.... and a spark plug will not fire in water or steam. Below is blow up of piston...
Socak
Sleeves were scarred on all three cylinders, one skirt was blown (seems to be the route of the problem), and heavy carbon build up on all pistons.
V153
Agreed. Looks more like a wrist pin bearing failure to me. Or connecting rod bearing, I've had one let go'n cause similar damage.
