84 evinrude spark plugs
huntbirds
Someone posted awhile ago that their motor would not get full power but with different plugs,not the champion, would achieve full power. My plugs are RL86Q, not C. Could this be a problem? They are champion plugs also.
hidef
Re: 84 evinrude spark plugs
What is the model number of you outboard? Not all models use the same plug.
Monte1961
SPARK PLUG, CHAMPION RL86 (2 required per assembly) Standard OEM.
huntbirds
When I start the motor and pull a plug wire it stalls. Iput in new condensers thinking that was the problem. Wrong. Where should I go next. P.S. It does seem to run better but still not right.
Monte1961
huntbirds Can you elaborate some more on exaclty what engine is doing or not doing? post back model # and hp.
huntbirds
I have recentley repaired the pump and carb. Put clear line to carb to see if gas was good and it is
huntbirds
Motor runs goog in garbage can but not good in the lake. maybe 50% power
Monte1961
OK. I hate to ask, but is the compression sufficient?.
Monte1961
With a compression gauge. It has a specific purpose. It measures psi in your cylinders. Can get at any local auto parts/wal-mart store for about 15 green backs. Do this first and post back results. A friend that work on motors may have one you can barrow!
