FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Hi - I need to know what the compression should be for an '84 Evinrude 9.9 - I have a Seloc manual for this motor, but I can't find a compression value in it. Thanks for the help ..... Mark
Thanks lindy46. Thats what I thought, but I wanted to be sure. Both cylinders are at 60 lbs. Could this be the reason for it to be really hard to start cold?
If they're both the same, put some Seafoam in the cylinders and let them soak overnight - could just be stuck rings. I did this with my 5.5hp and picked up about 10psi, and 70-75psi should allow motor to run ok.
