Re: 84 Evinrude 70 E70ELCRD gear oil filling.
You can fill it from the top if you have a couple extra hours on your hands.
It should be filled from the bottom hole, then there is a place for the air to escape as it is filled and you know for sure when it is full.
I will get 2 bottles of lower oil, make sure you use LOWER UNIT OIL, not 80/90, and fill one of them clear to the top, makes it alittle easier to fill it, when the oil comes out the top pop the top plug in and it will keep the oil from running out then get the bottom one in and you are done.
It is normal for a little to run out before you get the bottom plug in so no big deal there.
