droptheline
Thread starter- Joined
- May 2, 2008
- 109
Have had issues with my motor not firing on all four. brought it to a dealer who replaced plugs wires coils, no fix, tested timer base and said that was bad, still no fix, i couldnt afford for them to keep guessing so i have it back. There's not alot left, was told the stator tested ok and the battery is always charged. I was reading about recitifier testing on here and tried testing with multi meter on setting that looks like a sideways triangle with a vertical line thru it and has the audible sound. I disconnected the yellow/yellow & red wire from the power strip and test each wire with red lead with black lead grounded to base and then tried in reverse order and could not get a reading either way. was wondering if i was doing the test correctly? Thanks for the help
