I just purchased a 9.9 hp 84' chrysler sea king, when i run it i can turn the throttle all the way up and it will run good for a minute then on its own drop back down to about half throttle
. I changed the plugs, it idles good, I want full power!! I ran a little sea foam (about a gallon of gas and sea foam mix) through it and it seems to be running better but still not top notch, an outboard man told me that if i run it for a couple more gallons through it, that the sea foam will clear it up all the way. Is the jet clogged? If so, how do i clean? Keep running sea foam? never done this before. Thanks in adavance
