84 blackmax 150 cleaning???
crazyhunter
ive got a 84 150 and im going to be running it in saltwater for a couple of days had a thread and though i was told everything i need to do. well i was at a little going away party and talk to a mechanic he said i also need to take the cowl off and spray the motor down with water after i take it out. my question is will any electronics be affected by this???
oldman570
Re: 84 blackmax 150 cleaning???
A fresh water flush of the powerhead can be done, but if the motor is run in a fresh water river or lake after the use in salt water you should be fine. If you do flush it down make sure that the battery is disconnected while doing so and blow the entire powerhead down with compressed air and let it dry before hooking the battery up and using it again. Most of the electrical connections have some sort of waterproofing or cover on the connections. JMO
Oldman570
Dukedog
Very good idea on tha older stuff. Theres probably a lotta bolts and other parts that have tha paint knocked off of 'em. Tape up tha "air box" and/or tha carb inlets also. Another place is tha "tiller arm and clamp bracket. Especially tha tiller. Its a little one and will rust up really quick being that old. Put it in tha Sun for a day or two ta completly dry like said..............
M
Maxz695
Guest
it might be a good idea to spray the engine down particularly the electronics with PB Blaster. This will not hurt the electronics and keep a barrier to protect everything until you give it a good washing later on.
crazyhunter
thanks for the info guys i will spray the motor down when i take her out.
quicktach
Some good degreaser in greasy areas isn't a bad idea either. Don't spray into places like intakes or up under the flywheel. Major electrical components can be bagged and taped too ...just like you'd do on a car.
